You've sure lost me but that's ok . We often don't all speak the same language .
LOL. True enough, but this can be easily explained.
The factory throat plate is 1/8" thick and the 10" blade lowers below the top of the table no problem.
The OP made his own throat plate DIY, that's 3/8" thick so even at the lowest blade setting, it will not lay flush on the table because the blade is preventing that.
The factory throat plate came with a slot for the blade.
His DIY throat plate doesn't have a slot, yet.
He can't raise the blade under power like you typically do to make the slot/kerf because the throat plate is not safely flush in the insert depression.
That's the issue before us.
A good suggestion was to sticky tape the DIY plate carefully and directly on top of the factory plate and raise the blade under power to make the new slot.
The new slot will now align correctly when placed in the insert.
OR replace the 10" blade with a 8" blade the same kerf width from a dado stack.
The smaller diameter blade will allow the DIY plate to sit flush in the insert, no problem.
